ONTAP EMS reference
callhome.client events
callhome.client EMS events occur when ONTAP encounters issues associated with remote clients triggering events using the Manage ONTAP API.
callhome.client.app.alert
Severity
ALERT
This message occurs when a remote client accesses the node using Manage ONTAP® and triggers an event using the ems-autosupport-log API call with "auto-support" field set to "true". If your system is configured to do so, it generates and transmits an AutoSupport (or 'call home') message to NetApp technical support and to the configured destinations. Successful delivery of an AutoSupport message significantly improves problem determination and resolution.
Corrective Action
Identify and resolve the issue on the remote client that is using the Manage ONTAP API to trigger this event. If you need assistance, contact NetApp technical support.
Syslog Message
Call home for %s
subject (STRING): AutoSupport subject or title for this event.
callhome.client.app.emerg
Severity
EMERGENCY
Corrective Action
Syslog Message
Call home for %s
callhome.client.app.err
Severity
ERROR
Corrective Action
Syslog Message
Call home for %s
callhome.client.app.info
Severity
NOTICE
Corrective Action
Syslog Message
Call home for %s
callhome.client.app.notice
Severity
NOTICE
Corrective Action
Syslog Message
Call home for %s
