callhome.ctran events
callhome.ctran EMS events occur when ONTAP encounters issues associated with the Kernel Cluster Services (KCS) / Cluster Transaction Manager (CTRAN).
callhome.ctran.gcror.timeout
- Severity
ALERT
- Description
This message occurs when the Kernel Cluster Services (KCS) / Cluster Transaction Manager (CTRAN) detects that one or more newly selected Group Coordinators (GCs) are taking too long to successfully complete the GC Ready on Reselect procedure. If your system is configured to do so, it generates and transmits an AutoSupport (or 'call home') message to NetApp technical support and to the configured destinations. Successful delivery of an AutoSupport message significantly improves problem determination and resolution.
- Corrective Action
Call NetApp technical support immediately for further assistance.
- Syslog Message
Call home for GROUP COORDINATOR ROR TIMEOUT.
- Parameters
subject (STRING): AutoSupport subject or title for this event.
epoch (STRING): Identifying tag for multi node ASUP.
callhome.ctran.jpc.splitbrain
- Severity
ALERT
- Description
This message occurs when the Kernel Cluster Services (KCS) / Cluster Transaction Manager (CTRAN) detects that there is a disagreement in the cluster - a split brain - about which node has the Join Proposal Coordinator (JPC). If your system is configured to do so, it generates and transmits an AutoSupport (or 'call home') message to NetApp technical support and to the configured destinations. Successful delivery of an AutoSupport message significantly improves problem determination and resolution.
- Corrective Action
- Syslog Message
Call home for CTRAN JPC SPLIT BRAIN DETECTED.
- Parameters
callhome.ctran.proposal.stuck
- Severity
ALERT
- Description
This message occurs when the Kernel Cluster Services (KCS) / Cluster Transaction Manager (CTRAN) detects that the proposal is stuck. Proposal is the transaction between nodes in a cluster. If your system is configured to do so, it generates and transmits an AutoSupport (or 'call home') message to NetApp technical support and to the configured destinations. Successful delivery of an AutoSupport message significantly improves problem determination and resolution.
- Corrective Action
- Syslog Message
Call home for %s.
- Parameters
epoch (STRING): Identifying tag for multi-node ASUP.
