ONTAP EMS reference
callhome.nvmem events
callhome.nvmem EMS events occur when ONTAP encounters issues associated with Non-Volatile memory (NVMEM) card lithium battery voltage.
callhome.nvmem.volt.hi
Severity
ALERT
This message occurs when the sensor for the Non-Volatile memory (NVMEM) card lithium battery has an excessively high voltage. If your system is configured to do so, it generates and transmits an AutoSupport (or 'call home') message to NetApp technical support and to the configured destinations. Successful delivery of an AutoSupport message significantly improves problem determination and resolution.
Corrective Action
First, correct any environmental or battery problems. If the problem continues, replace the controller module. If you need assistance, contact NetApp technical support.
Syslog Message
Call home for NVMEM VOLTAGE HIGH
subject (STRING): AutoSupport subject or title for this event.
callhome.nvmem.volt.lo
Severity
ALERT
This message occurs when the sensor for the Non-Volatile memory (NVMEM) card lithium battery has an excessively low voltage. If your system is configured to do so, it generates and transmits an AutoSupport (or 'call home') message to NetApp technical support and to the configured destinations. Successful delivery of an AutoSupport message significantly improves problem determination and resolution.
Corrective Action
Syslog Message
Call home for NVMEM VOLTAGE LOW
