cf.nduincomplete events
cf.nduincomplete EMS events occur when a nondisruptive upgrade fails.
cf.nduIncomplete
- Severity
INFORMATIONAL
- Description
This message occurs when a nondisruptive upgrade fails.
- Corrective Action
Resolve the reason for the failure and retry the nondisruptive upgrade from the failed step.
- Syslog Message
(None).
- Parameters
token (STRING): Unique token that identifies an instance of a nondisruptive upgrade.
host (STRING): Name of the node that failed the nondisruptive upgrade.
reason (STRING): Reason for the upgrade failure.
