ONTAP EMS reference
cf.nm events
cf.nm EMS events occur when ONTAP encounters issues associated with HA interconnect network interface card operations.
cf.nm.nicReset
Severity
NOTICE
This message occurs when the controller performs a soft reset of the HA interconnect card as part of automatic recovery from a timeout or link error.
Corrective Action
(None).
Syslog Message
HA interconnect: Initiating soft reset on card %d due to %s.
nic_num (INT): Interconnect NIC number.
reason (STRING): Describes why the soft reset was initiated. Possible reasons: rendezvous jammed rendezvous fm timeout rendezvous peer-connect timeout
cf.nm.nicViError
Severity
INFORMATIONAL
This message occurs when any error is detected in any virtual interface while handling a link transition.
Corrective Action
(None).
Syslog Message
HA interconnect: NIC %d has an error on %s (virtual interface #%d): %s.
vi_name (STRING): Name of the virtual interface.
vinum (INT): Virtual interface number.
origin (STRING): Origin of the error.
