ONTAP EMS reference
cloud.dbinfo events
cloud.dbinfo EMS events occur when ONTAP detects that the connection to the cloud database has been closed, which the database service may do periodically for enhanced security.
cloud.DBInfo
Severity
NOTICE
This message occurs when ONTAP detects that the connection to the cloud database has been closed, which the database service may do periodically for enhanced security. ONTAP will automatically reopen the connection for continued operation.
Corrective Action
None.
Syslog Message
Cloud database service on table "%s" with message "%s".
db_table (STRING): Name of the cloud database table associated with this ONTAP Cloud instance.
info_msg (STRING): Message in progress to the closed database when the closed database connection was detected.
