coredump.dr events
coredump.dr EMS events occur when ONTAP encounters issues associated with disaster recovery (DR) partner sparecore dump operations.
coredump.dr.dump.not.started
- Severity
ERROR
- Description
This message occurs when coredump subsystem detects that disaster recovery (DR) partner sparecore dump did not start.
- Corrective Action
Log in to service processor and power cycle the DR partner that may not have started dumping core.
- Syslog Message
DR partner sparecore dump failed to start.
- Parameters
(None).
coredump.dr.spare.abort
- Severity
INFORMATIONAL
- Description
This message occurs when coredump subsystem attempts to abort any sparecore dump that might be in progress on disaster recovery (DR) partner. This process can take up to 60 seconds. During this time, other coredump operations are not serviced.
- Corrective Action
(None).
- Syslog Message
Pausing to abort DR partner sparecore dump on %s because %s.
- Parameters
diskuid (STRING): UID of DR partner sparecore dump disk.
reason (STRING): Reason for aborting the DR partner sparecore dump.
coredump.dr.spare.noAbort
- Severity
ERROR
- Description
This message occurs when coredump subsystem is unable to abort any sparecore dump that might be in progress on disaster recovery (DR) partner.
- Corrective Action
Log in to service processor and power cycle the DR partner that is still dumping core.
- Syslog Message
DR partner sparecore dump could not be aborted on disk %s because %s.
- Parameters
reason (STRING): Reason for abort failure.
