disk.fence events
disk.fence EMS events occur when a node's access to a disk is blocked due to a high-availability (HA) takeover event.
disk.fence.BridgeIOBlocked
- Severity
NOTICE
- Description
This message occurs when a node's access to a disk is blocked due to a high-availability (HA) takeover event. The disk should still be accessible via other nodes in the system.
- Corrective Action
(None).
- Syslog Message
Disk "%s" reported fence blocked status on shelf "%s". Fence set by node: "%s", Fence Time: "%s."
- Parameters
diskName (STRING): Name of the disk reporting the BRIDGE_IO_BLOCKED status.
shelf_id (STRING): Shelf ID and NSM ID that returned the BRIDGE_IO_BLOCKED status.
fence_setter_uid (STRING): UUID of the node that sent the fence request to the bridge.
fence_time (STRING): Exact timestamp indicating when the node sent the fence request to the bridge.
