ha.dataaggregate events
ha.dataaggregate EMS events occur when an aggregate ownership change has failed after offlining the aggregate.
ha.dataAggregate.offline.warning
- Severity
EMERGENCY
- Description
This message occurs when an aggregate ownership change has failed after offlining the aggregate.
- Corrective Action
Verify that the VLDB ring is online by using the 'cluster ring show' command. Then retry the giveback by using the 'storage failover giveback' command.
- Syslog Message
The local node has failed to change the ownership of the partner node's data aggregates after offlining the aggregate.
- Parameters
(None).
