ONTAP EMS reference
hotplug.init events
hotplug.init EMS events occur when ONTAP encounters issues associated with hot plug module initialization.
hotplug.init.failed
Severity
ALERT
This message occurs when the "slot module insert" command encounters an error while initializing the module.
Corrective Action
Retry the "slot module remove" and "slot module insert" commands. If errors persist, contact NetApp technical support.
Syslog Message
Initialization of ports "%s" in slot %d failed after hot plug module insert. Error: "%s".
port_list (STRING): Port list of the inserted module.
slot (INT): Slot number of the module.
reason (STRING): Error that was encountered during module initialization.
hotplug.init.success
Severity
NOTICE
This message occurs when the "slot module insert" command successfully initializes the ports of the inserted module.
Corrective Action
(None).
Syslog Message
Initialization of ports "%s" in slot %d succeeded after hot plug module insert.
