ONTAP EMS reference
hybaggrcopy.srcgeommismatch events
hybaggrcopy.srcgeommismatch EMS events occur when an aggregate cannot be copied.
hybAggrCopy.srcGeomMismatch
Severity
ERROR
This message occurs when an aggregate cannot be copied. The issue is either that the source is a hybrid aggregate and the destination is not, or there is a mismatch between the disk geometries of the source and destination hybrid aggregates.
Corrective Action
Verify that the source and destination are both hybrid aggregates. Verify that the destination aggregate has at least the same number each of hard disk drives (HDDs) and solid state drives (SSDs) as the source aggregate. Verify that the disk size and type of each disk of the source aggregate matches those of the destination aggregate.
Syslog Message
Aggregate %s cannot be copied. Either the source is a hybrid aggregate but the destination is not, or the source and destination hybrid aggregate geometries do not match.
srcaggr (STRING): Name of the source aggregate.
