license.check events
license.check EMS events occur when ONTAP encounters issues associated with the license checker and Base license validation.
license.check.expired
- Severity
ERROR
- Description
This message occurs when the license checker determines that the Base license has expired. If this is the case, you cannot add nodes to the cluster
- Corrective Action
Install a permanent Base license on this cluster.
- Syslog Message
License Checking: Expired Base license (%s)
- Parameters
error (STRING): Interpreted error string from the license validation check.
license.check.failed
- Severity
ERROR
- Description
This message occurs when the license checker has run and has been unable to validate the Base license due to an internal error. If there is not a valid Base license, then no additional nodes can be added to the cluster.
- Corrective Action
Install a valid Base license on this cluster.
- Syslog Message
License Checking: internal error validating Base license (%s)
- Parameters
license.check.invalid
- Severity
ERROR
- Description
This message occurs when the license checker determines that the Base license is incorrect in some way. If Base license is invalid, you cannot add nodes to the cluster.
- Corrective Action
- Syslog Message
License Checking: The Base license is invalid (%s)
- Parameters
license.check.mirror
- Severity
ERROR
- Description
This message occurs when the license checker has run and has determined that at least one volume is being mirrored but there isn't a valid Mirror license installed.
- Corrective Action
Install a valid Mirror license on this cluster.
- Syslog Message
License Checking: Mirror License failure: (%s)
- Parameters
volume (STRING): The first volume detected that requires a Mirror license
license.check.missing
- Severity
ERROR
- Description
This message occurs when the license checker determines that the Base license is missing. If this is the case, you cannot add nodes to the cluster.
- Corrective Action
Reinstall the Base license.
- Syslog Message
License Checking: Missing Base license
- Parameters
(None).
license.check.nodes
- Severity
ERROR
- Description
This message occurs when the license checker determines that the number of nodes in the cluster exceeds the number of nodes allowed by the Base license
- Corrective Action
Install a Base license with the correct node count, or remove nodes from the cluster using the unjoin command until the number of total nodes is equal to, or less than, the specified node count limit.
- Syslog Message
License Checking: Current node count (%d) exceeds the licensed node limit (%d)
- Parameters
nodecount (INT): Number of nodes detected in the cluster
nodelimit (INT): Number of nodes allowed by the Base license
license.check.nonodes
- Severity
ERROR
- Description
This message occurs when the license checker determines that it cannot retrieve the number of nodes in the cluster to compare against the Base license node count. If this is the case, then you cannot add nodes to the cluster.
- Corrective Action
Re-install the Base license so that the node count is correctly reflected. If that fails to fix the problem please contact Customer Support.
- Syslog Message
License Checking: Cannot to retrieve the number of nodes in the cluster.
- Parameters
(None).
license.check.warn.expired
- Severity
ERROR
- Description
This message occurs when the license checker determines that a license has expired.
- Corrective Action
Install a permanent license on this cluster.
- Syslog Message
The license for package "%s" expired on %s.
- Parameters
package (STRING): Name of the license package.
expiration (STRING): Expiration date.
license.check.warn.expiring
- Severity
ERROR
- Description
This message occurs when the license checker determines that a license is within a week of its expiration date.
- Corrective Action
- Syslog Message
The license for package "%s" expires on %s.
- Parameters
