lmgr.precommit events
lmgr.precommit EMS events occur when ONTAP encounters issues associated with SMB oplock or NFSv4 delegation recall during aggregate operations.
lmgr.precommit.oplock.recall.fail
- Severity
ALERT
- Description
This message occurs when the system fails aggregate giveback or relocation because SMB oplock or NFSv4 delegation recall fails. Giveback or relocation cannot proceed until all oplocks are recalled successfully or the lock manager pre-commit phase is forced, in which case cached writes in clients might be lost.
- Corrective Action
There are two options for allowing aggregate giveback or relocation to proceed: (1) Force the sendhome pre-commit phase. For aggregate relocation, this can be done by specifying the '-override-destination-checks true' option. For giveback, this can be done by specifying the '-require-partner-waiting false' option. (2) Recall oplocks for Vservers on aggregates participating in the operation by using the 'volume qtree oplocks -volume <vol-name> -qtree <qtree-name> -vserver <vserver-name> -oplock-mode disable' command for volumes or qtrees with oplocks enabled. Then retry the operation, and reenable oplocks after the operation is complete. If the error persists, contact NetApp technical support for assistance.
- Syslog Message
Aggregate "%s" failed giveback or relocation because lock manager oplock recall failed. Error: %s.
- Parameters
aggrname (STRING): Aggregate name.
error (STRING): Error details.
lmgr.precommit.oplock.recall.fail.oam
- Severity
ALERT
- Description
- Corrective Action
There are two options for allowing aggregate relocation to proceed: (1) Force the sendhome pre-commit phase. It can be done by specifying the '-override-destination-checks true' option. (2) Recall oplocks for Vservers on aggregates participating in the operation by using the 'volume qtree oplocks -volume <vol-name> -qtree <qtree-name> -vserver <vserver-name> -oplock-mode disable' command for volumes or qtrees with oplocks enabled. Then retry the operation, and reenable oplocks after the operation is complete. To allow aggregate giveback to proceed: (1) Recall oplocks for Vservers on aggregates participating in the operation by using the 'volume qtree oplocks -volume <vol-name> -qtree <qtree-name> -vserver <vserver-name> -oplock-mode disable' command for volumes or qtrees with oplocks enabled. Then retry the operation, and reenable oplocks after the operation is complete. If the error persists, contact NetApp technical support for assistance.
- Syslog Message
- Parameters
lmgr.precommit.oplock.recall.forced
- Severity
NOTICE
- Description
This message occurs when the lock manager oplock recall fails during aggregate giveback or relocation, but the pre-commit phase has been forced to proceed. It is possible that cached writes in clients might have been lost as a result.
- Corrective Action
(None).
- Syslog Message
Lock manager oplock recall failed for aggregate "%s" during giveback or relocation. The failure abort was overridden. Error: %s.
- Parameters
lmgr.precommit.oplock.recall.timeout
- Severity
ALERT
- Description
This message occurs when the lock manager oplock recall fails during aggregate giveback or relocation because the recalls could not be completed within the internal timeout window. The timeout typically can expire due to CPU overload, slow client response, or a large number of open files.
- Corrective Action
The timeout can can be ignored by specifying the '-override-vetoes true' option in the giveback or relocation command.
- Syslog Message
Lock manager oplock recall failed to be completed for aggregate "%s" within %d seconds.
- Parameters
timeout (INT): Timeout value.
