ONTAP EMS reference
nblade.flexcachecaaccess events
nblade.flexcachecaaccess EMS events occur when a client tries to access a FlexCache® volume via SMB3 using a continuously available share but is denied because FlexCache does not support persistent handle capability.
Nblade.flexcacheCAAccess
Severity
ERROR
This message occurs when a client tries to access a FlexCache® volume via SMB3 using a continuously available share but is denied because FlexCache does not support persistent handle capability.
Corrective Action
Either remove the continuously available property from the CIFS share or create a new share without this property to access the FlexCache volume over SMB.
Syslog Message
Attempt to access FlexCache volume with MSID %u via SMB3 over a continuously available share is denied.
msid (INT): MSID of the FlexCache volume being accessed.
