ONTAP EMS reference
nblade.nfstlsdisabled events
nblade.nfstlsdisabled EMS events occur when the client is trying to use NFS over TLS (Transport Layer Security), but the NFS feature is marked as disabled on the server side.
Nblade.NfsTlsDisabled
Severity
ALERT
This message occurs when the client is trying to use NFS over TLS (Transport Layer Security), but the NFS feature is marked as disabled on the server side.
Corrective Action
Contact NetApp technical support.
Syslog Message
Failed to create NFS over TLS (Transport Layer Security) connection, because NFS over TLS is disabled for SVM: "%s".
vsName (STRING): Storage virtual machine (SVM) name.
