ONTAP EMS reference
netif.badeeprom events
netif.badeeprom EMS events occur when the network interface has an electronically erasable programmable read-only memory (EEPROM) with a bad cyclic redundancy check (CRC) or media access control (MAC) address.
netif.badEeprom
Severity
EMERGENCY
This message occurs when the network interface has an electronically erasable programmable read-only memory (EEPROM) with a bad cyclic redundancy check (CRC) or media access control (MAC) address.
Corrective Action
Replace the component associated with the network interface (PCIe card or controller motherboard).
Syslog Message
Network interface %s has an EEPROM with a bad CRC or MAC address.
ifName (STRING): Name of the network interface; for example, "e8a".
