ONTAP EMS reference
no.halt events
no.halt EMS events occur when ONTAP encounters issues associated with automatic shutdown being disabled.
no.halt.brokenDisk
Severity
ALERT
This message occurs when the option raid.timeout is set to 0 or if the option hasn't been set by the user, disabling automatic shutdown on a disk failure.
Corrective Action
Add an appropriate spare disk.
Syslog Message
%s in RAID group "%s" %s broken. Automatic system shutdown has been disabled.
type (STRING): Type of disk.
rgname (STRING): RAID group name.
verb (STRING): Failed disk verb.
no.halt.brokenDisk.notice
Severity
NOTICE
This message occurs when a node is in a degraded state because of a broken disk, but the option raid.timeout is set to 0 or its value hasn't been modified by the user, disabling automatic shutdown on a disk failure. Shutdown is to encourage you to replace broken disks. This message occurs on a capacity-optimized platform with broken disks irrespective of the value of the option raid.timeout.
Corrective Action
Consult other logged messages or use the "storage disk show -broken" command to determine the identity of broken disks. Remove any broken disks. Automatic system shutdown can be enabled by altering the "raid.timeout" value using the "storage raid-options modify" command. NOTE: The option "raid.timeout" will not affect the automatic shutdown on a capacity-optimized platform.
Syslog Message
%s. automatic system shutdown is disabled. Replace the disk immediately.
type (STRING): Type of degradation.
no.halt.nvramLowBatt.info
Severity
ALERT
This message occurs when the option raid.timeout has been set to 0, disabling automatic shutdown on a low NVRAM Battery condition.
Corrective Action
Replace the NVRAM battery. Automatic system shutdown can be enabled by altering the "raid.timeout" value using the "storage raid-options modify" command.
Syslog Message
Automatic system shutdown is disabled. If the NVRAM battery is dangerously low, replace it immediately.
(None).
no.halt.nvramLowBatteries
Severity
ALERT
This message occurs when the option raid.timeout is set to 0, disabling automatic shutdown on a low NVRAM Batteries condition.
Corrective Action
Replace the NVRAM batteries.
Syslog Message
NVRAM batteries are dangerously low. Automatic system shutdown is disabled. Replace the batteries immediately!
(None).
no.halt.nvramLowBattery
Severity
ALERT
This message occurs when the option raid.timeout is set to 0, disabling automatic shutdown on a low NVRAM Battery condition.
Corrective Action
Syslog Message
NVRAM battery is dangerously low. Automatic system shutdown is disabled. Replace the battery immediately!
(None).
no.halt.nvramLowBatts.info
Severity
NOTICE
This message occurs when the option raid.timeout has been set to 0, disabling automatic shutdown on a low NVRAM Batteries condition.
Corrective Action
Replace the NVRAM batteries. Automatic system shutdown can be enabled by altering the "raid.timeout" value using the "storage raid-options modify" command.
Syslog Message
Automatic system shutdown is disabled. If the NVRAM batteries are dangerously low, we encourage you to replace it immediately.
(None).
