ONTAP EMS reference
nvmf.subsystem events
nvmf.subsystem EMS events occur when ONTAP encounters issues associated with NVMe-oF target subsystems and SnapMirror® Active Synchronous relationships.
nvmf.subsystem.hidden
Severity
ALERT
This message occurs when a NVMe-oF target subsystem is hidden due to a SnapMirror® Active Synchronous relationship going out of sync. The NVMe-oF target subsystem is no longer accessible from the host.
Corrective Action
Restore NVMe-oF target subsystem access to the host by using the "snapmirror resync" command to bring the out-of-sync relationship back in sync. If "snapmirror resync" does not fix the issue, contact NetApp technical support.
Syslog Message
NVMe-oF target subsystem NQN %s is hidden and reason code is %d.
subsystem_nqn (STRING): NVMe Qualified Name (NQN) of the subsystem.
reason_code (INT): Reason code for NVMe-oF target subsystem hiding.
nvmf.subsystem.unhidden
Severity
NOTICE
This message occurs when a previously hidden NVMe-oF target subsystem is now unhidden.
Corrective Action
(None).
Syslog Message
NVMe-oF target subsystem NQN %s is unhidden.
