nvram.parity events
nvram.parity EMS events occur when excessive parity errors are reported by the NVRAM complex.
nvram.parity.threshold
- Severity
ERROR
- Description
This message occurs when excessive parity errors are reported by the NVRAM complex. Your system is at risk of data loss in the event of a power failure.
- Corrective Action
Contact NetApp technical support.
- Syslog Message
Excessive parity errors detected in the NVRAM module.
- Parameters
(None).
