ONTAP EMS reference
platform.insufficientmemory events
platform.insufficientmemory EMS events occur when there is not enough system memory for the system to function, likely due to slots that contain incorrect, failed, or missing DIMMs.
platform.insufficientMemory
Severity
EMERGENCY
This message occurs when there is not enough system memory for the system to function, likely due to slots that contain incorrect, failed, or missing DIMMs.
Corrective Action
Replace the incorrect, failed, or missing DIMMs.
Syslog Message
Not enough system memory for the system to function. Detected %d GB, expected %d GB. Check DIMMs slots %s.
mem_detected (INT): Amount of system memory that was detected.
mem_expected (INT): Amount of system memory that this model supports.
slots (STRING): List of slots with incorrect, failed, or missing DIMMs.
