ONTAP EMS reference
query.execution events
query.execution EMS events occur when ONTAP encounters issues associated with SQL query processing.
query.execution.console
Severity
NOTICE
This message occurs when the dotsql command-line program processes an SQL query.
Corrective Action
(None).
Syslog Message
(None).
query (STRING): Query that was executed.
query.execution.failed
Severity
NOTICE
This message occurs when a SQL query of the system fails for any reason.
Corrective Action
This type of failure can occur legitimately during the course of normal system operation. In cases of unexpected failure, the requestor provides diagnostic advice.
Syslog Message
(None).
error (STRING): Error message that occurred.
