raid.unpartition events
raid.unpartition EMS events occur when ONTAP encounters issues associated with disk unpartitioning operations.
raid.unpartition.disk
- Severity
NOTICE
- Description
This message indicates a disk was successfully unpartitioned.
- Corrective Action
(None).
- Syslog Message
Disk unpartition successful on %s.
- Parameters
disk_info (STRING): Formatted information of the disk. This includes the disk's containing volume name and other attributes, such as shelf, bay, vendor, model, firmware revision, serial number, and type.
shelf (STRING): Shelf identifier where the disk is located.
bay (STRING): Disk bay within the shelf where the disk is located.
vendor (STRING): Name of the disk vendor.
model (STRING): Model string of the disk.
firmware_revision (STRING): Disk firmware revision number.
serialno (STRING): Serial number of the disk.
disk_type (INT): Type of disk.
disk_rpm (STRING): Rotational speed of the disk, in RPM.
carrier (STRING): Unique ID of the carrier in which the disk is installed.
site (STRING): For a MetroCluster(tm) configuration, indicates the site {Local|Remote} where the disk is located. For non-MetroCluster configurations, site is 'Local'.
raid.unpartition.disk.fail
- Severity
NOTICE
- Description
This message occurs when an attempt to unpartition a disk fails. The error and error_info fields indicate the reason why the attempt failed.
- Corrective Action
(None).
- Syslog Message
Disk unpartition failed on %s, error %s, additional error info (%s).
- Parameters
error (STRING): String name for the error.
error_info (STRING): Additional error information.
