ONTAP EMS reference
reg.key events
reg.key EMS events occur when ONTAP encounters issues associated with invalid registry keys.
reg.key.invalid
Severity
ERROR
This message occurs when ONTAP® software cannot access the registry because the key is not valid.
Corrective Action
Use a valid key.
Syslog Message
registry: Invalid key %s: %s
key (STRING): Registry key that is not valid.
reason (STRING): Reason the key is not valid.
accessID (STRING): Shows how the registry was accessed.
reg.key.null
Severity
ERROR
This message occurs when the value of key is NULL while the registry set is being implemented on a vFiler(tm) key.
Corrective Action
(None).
Syslog Message
vfiler_registry_set: Set of key=%s received NULL for value.
keyName (STRING): Name of the key.
