ONTAP EMS reference
secd.nfsauth events
secd.nfsauth EMS events occur when ONTAP encounters issues associated with NFS authorization.
secd.nfsAuth.noCifsCred
Severity
ERROR
This message occurs when an NFS authorization attempt fails because of the inability of the system to retrieve a matching CIFS credential for use in multi-protocol security operations.
Corrective Action
Examine the failure details to determine corrective action. This failure usually occurs because the system is unable to communicate with Active Directory.
Syslog Message
vserver (%s) NFS authorization cannot retrieve CIFS credentials. %s
vserverName (STRING): vserver associated with this operation.
failureDetail (STRING): Error journal is a collection of events leading up to a failure. This failure is likely to impact many (if not all) users, and might reflect a misconfiguration or environmental problem..
secd.nfsAuth.noCifsSid
Severity
ERROR
This message occurs when an NFS authorization attempt fails because the system could not resolve an associated Windows security identifier (SID).
Corrective Action
Syslog Message
vserver (%s) Unable to resolve CIFS security identifier (SID). %s
secd.nfsAuth.noCifsUser
Severity
ERROR
This message occurs when an NFS authorization attempt fails because the Windows user that NFS maps to cannot be found.
Corrective Action
Examine the failure details to determine corrective action. Common failures include faulty UNIX-to-Windows name mapping rules, an improperly configured default Windows user, or the system is unable to communicate with Active Directory.
Syslog Message
vserver (%s) Mapped CIFS user name not found. %s
secd.nfsAuth.noNameMap
Severity
ERROR
This message occurs when an NFS authorization attempt fails because of a UNIX to Windows name mapping issue.
Corrective Action
Examine the failure details to determine corrective action. Common failures include no appropriate UNIX-to-Windows name mapping rules, no configured default Windows user, or the inability of the system to contact LDAP if LDAP is configured for name mapping.
Syslog Message
vserver (%s) Cannot map UNIX name to CIFS name. %s
secd.nfsAuth.noUnixCreds
Severity
ERROR
This message occurs when an NFS authorization attempt fails because credentials for a UNIX user cannot be determined.
Corrective Action
Examine the error journal for the collection of events that led to the specific failure. A common failure is the inability to communicate with NS-SWITCH authorization sources.
Syslog Message
Vserver "%s" cannot determine UNIX identity. %s
vserverName (STRING): Vserver associated with this operation.
secd.nfsAuth.problem
Severity
ERROR
This message occurs when an NFS authorization attempt fails.
Corrective Action
Examine the failure details to determine corrective action. Common failures include name mapping issues, or the inability to communicate with domain controllers, NIS servers, or LDAP servers due to connectivity or configuration problems.
Syslog Message
vserver (%s) General NFS authorization problem. %s
