ONTAP EMS reference
ses.bridge events
ses.bridge EMS events occur when ONTAP encounters issues associated with bridge firmware.
ses.bridge.fw.getFailWarn
Severity
ERROR
This message occurs when the bridge firmware revision cannot be obtained.
Corrective Action
Check the connection to the bank of Maxtor drives.
Syslog Message
On channel %s, the bridge firmware revision could not be obtained using disk IDs %d-%d.
ChannelName (STRING): Name of the adapter or switch port that the system tried to get the revision number of.
DiskID (INT): Starting ID of the bank of Maxtor disks that was used to obtain the bridge firmware.
DiskRange (INT): Number of drives in that bank of Maxtor disks.
ses.bridge.fw.mmErr
Severity
ERROR
This message occurs when the bridge firmware revision is inconsistent.
Corrective Action
Check the firmware revision number and make sure that they are consistent. You might have to update the firmware.
Syslog Message
On channel %s, the bridge firmware revision appears to be inconsistent : %8.8s and %8.8s.
ChannelName (STRING): Name of the channel that contains the inconsistent firmware revision.
PrevRev (STRING): Previous firmware revision.
CurRev (STRING): Current firmware revision.
