ONTAP EMS reference
set.cluster events
set.cluster EMS events occur during an ONTAP upgrade to 9.17.1 or a later release, when the existing auto-enable-analytics configuration parameter is changed from "false" to "-" (not set).
set.cluster.fsa.default
Severity
NOTICE
This message occurs during an ONTAP upgrade to 9.17.1 or a later release, when the existing auto-enable-analytics configuration parameter is changed from "false" to "-" (not set). "-" is the default state starting with ONTAP 9.17.1.
Corrective Action
(None).
Syslog Message
The auto-enable-analytics parameter in the cluster configuration has been changed from "false" to "-" during an ONTAP upgrade.
(None).
