sfu.nsmdownloadfailed events
sfu.nsmdownloadfailed EMS events occur when a disk shelf firmware update fails to download disk shelf firmware to a disk shelf successfully.
sfu.NSMDownloadFailed
- Severity
ERROR
- Description
This message occurs when a disk shelf firmware update fails to download disk shelf firmware to a disk shelf successfully.
- Corrective Action
Go to the NetApp Support Site at https://mysupport.netapp.com/site/downloads/firmware/disk-shelf-firmware and try downloading the disk shelf firmware again by using the (advanced privilege) "storage shelf firmware update" command.
- Syslog Message
%s: Download failed on %s on disk shelf controller module %s on disk shelf %s.%d.
- Parameters
cmdName (STRING): Name of the command issued, such as "storage shelf firmware update".
fileName (STRING): Name of the file in /etc/shelf_fw that was being downloaded.
module (STRING): Module on which the disk shelf firmware download failed.
channelNameSES (STRING): Name of the adapter port or switch port on the SCSI enclosure services (SES) device on which the disk shelf firmware download failed.
shelfId (INT): ID of the disk shelf on which the disk shelf firmware download failed.
