ONTAP EMS reference
sm.syncmirror events
sm.syncmirror EMS events occur when a sync granular CG relationship transitions from in-sync status to out-of-sync status.
sm.syncmirror.out.of.sync
Severity
ALERT
This message occurs when a sync granular CG relationship transitions from in-sync status to out-of-sync status.
Corrective Action
Verify network connections between the primary cluster and the secondary cluster. Check for error information in the "snapmirror show" command output for the relationship. Quiesce the relationship if the condition cannot be addressed immediately.
Syslog Message
Sync granular CG relationship with source path %s and destination path %s has transitioned from in-sync to out-of-sync for the follow reason: %s.
src_path (STRING): Source path of the sync granular CG relationship that transitioned from in-sync to out-of-sync.
dst_path (STRING): Destination path of the sync granular CG relationship that transitioned from in-sync to out-of-sync.
reason (STRING): Reason that the relationship went out-of-sync.
