ONTAP EMS reference
token.max events
token.max EMS events occur when the maximum number of tokens that can be created in a volume is determined.
token.max.count.in.volume
Severity
INFORMATIONAL
This message occurs when the maximum number of tokens that can be created in a volume is determined.
Corrective Action
(None).
Syslog Message
Volume %s can contain up to %d tokens.
volume_name (STRING): Name of the volume in which tokens can be created.
max (INT): Maximum number of tokens in the volume.
