vnvram.jswap events
vnvram.jswap EMS events occur when ONTAP encounters issues associated with NVLog journal swap operations.
vnvram.jswap
- Severity
NOTICE
- Description
This message occurs whenever a journal swap event takes place.
- Corrective Action
(None).
- Syslog Message
%s journal swap to mode (%s) - %s: elapsed %d ms.
- Parameters
jswap_request_type (STRING): This was a dynamic request or manual swap request.
jswap_type (STRING): The type of journal swap (ephemeral memory or ephemeral disk).
jswap_result (STRING): The result of the journal swap operation.
jswap_time_ms (INT): Time taken to write the NVRAM section.
vnvram.jswap.failure
- Severity
ERROR
- Description
This message occurs whenever a NVLog journal swap fails.
- Corrective Action
(None).
- Syslog Message
%s NVLog journal swap (%s) - Failure: %s.
- Parameters
jswap_request_type (STRING): This was a dynamic, manual, or internal swap request.
jswap_type (STRING): The type of NVLog journal swap operation being attempted.
jswap_reason (STRING): The reason for the failure in the NVLog journal swap.
vnvram.jswap.long
- Severity
ERROR
- Description
This message occurs when the NVLOG journal swap operation takes too long.
- Corrective Action
(None).
- Syslog Message
NVLog journal swap (%s) took too long: elapsed: %d sec.
- Parameters
reason (STRING): Reason for message.
elapsed_sec (INT): Time elapsed in seconds.
vnvram.jswap.mode
- Severity
NOTICE
- Description
This message occurs whenever the NVLog journal swap mode is updated.
- Corrective Action
(None).
- Syslog Message
NVLog journal swap mode set to %s.
- Parameters
jswap_mode (STRING): The NVLog journal swap mode.
