ONTAP EMS reference
vserver.vol events
vserver.vol EMS events occur when ONTAP encounters issues associated with destination DP volume size modifications in storage-limit enabled SVMs.
vserver.vol.max.size.reduced
Severity
NOTICE
This message occurs when the size or the maximum autosize of a destination DP volume in a storage-limit enabled SVM is reduced, which is part of a SnapMirror relationship.
Corrective Action
(None).
Syslog Message
Maximum-autosize or size of destination volume "%s" in the storage-limit enabled SVM "%s" is reduced.
volume_name (STRING): Name of the storage virtual machine (SVM).
vserver_name (STRING): Name of the volume.
vserver.vol.modify.on.dest.failed
Severity
ERROR
This message occurs when an attempt to modify either the size or maximum autosize of a source volume in a SnapMirror sync relationship fails because it fails to modify the size or maximum autosize at the destination DP volume which is in a storage limit enabled SVM.
Corrective Action
Check the reason for destination volume modify failure and take appropriate actions.
Syslog Message
Maximum-autosize or size of destination volume "%s" which is in a storage-limit enabled SVM "%s" was not modified. Reason: "%s"
reason (STRING): Error message.
