ONTAP EMS reference
wafl.enc events
wafl.enc EMS events occur when ONTAP encounters issues associated with the WAFL aggregate encryption keys metafile.
wafl.enc.aggrMFRecreated
Severity
NOTICE
This message occurs when the system detects a corrupted WAFL aggregate encryption keys metafile and creates a corrected replacement.
Corrective Action
(None).
Syslog Message
"Recreated aggregate %s encryption keys metafile."
aggr (STRING): Aggregate name.
wafl.enc.aggrMFRecreateFail
Severity
ALERT
This message occurs when the system detects a corrupted WAFL aggregate encryption keys metafile and is unable to create a corrected replacement. The system might not be able to mount volumes.
Corrective Action
Contact NetApp technical support.
Syslog Message
"Failed to recreate aggregate %s encryption key metafile."
