ONTAP EMS reference
wafl.flexaggr events
wafl.flexaggr EMS events occur when ONTAP encounters issues associated with local root flexaggregate identification during mount.
wafl.flexaggr.multi.root
Severity
ERROR
This message occurs when the system found multiple local root flexaggregates from volume location database (VLDB) during the mount process. It might cause a boot problem or the system might exhibit unexpected behavior.
Corrective Action
Contact NetApp technical support.
Syslog Message
Found multiple local root flexaggregate from VLDB during mount.
(None).
wafl.flexaggr.no.root
Severity
ERROR
This message occurs when the system is unable to find any local root flexaggregate from volume location database (VLDB) during the mount process. If there is no root flexaggregate, data aggregates may not come online.
Corrective Action
Syslog Message
Failed to find any local root flexaggregate from VLDB during mount.
(None).
wafl.flexaggr.rgadd.nonstatic.alloc.verify
Severity
ALERT
A flexaggr has been reinitialized. We must verify the RG add upgrade to non-static allocation (if such an upgrade was required or already done) has been left in a consistent state between the two partner flexaggrs.
Corrective Action
Syslog Message
Flexaggr %s has been reinitialized. We must verify the RG add upgrade to non-static allocation (if such an upgrade was required or already done) has been left in a consistent state between the two partner flexaggrs.
flexaggrname (STRING): Flexaggregate name.
wafl.flexaggr.rgadd.upgrade.handshake.error
Severity
ERROR
An error has occuring during the Raid Group Add non-static allocation upgrade handshake.
Corrective Action
Syslog Message
Flexaggr %s has encountered an error (%d) during Raid Group Add non-static allocation upgrade handshake.
error (INT): Error code.
