wafl.ondemand events
wafl.ondemand EMS events occur when ONTAP encounters issues associated with file operation space reservation.
wafl.ondemand.aggr.rsv.fail
- Severity
ERROR
- Description
This message occurs when Data ONTAP® fails to reserve space for a file operation due to lack of space on the aggregate.
- Corrective Action
Create free space on the aggregate by either adding more disks or manually deleting data. If this condition persists, contact NetApp technical support for further assistance.
- Syslog Message
Insufficient space on aggregate '%s %s' to perform file operation on volume '%s%s%s' (failed to re-create %s flexible space pool).
- Parameters
owner (STRING): Owner of the aggregate.
aggr (STRING): Name of the aggregate.
vol (STRING): Name of the volume.
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
fsptype (STRING): Type of the flexible space pool.
wafl.ondemand.destroy.pending
- Severity
NOTICE
- Description
This message occurs when a file operation cannot be immediately destroyed because the destination file has been captured in one or more snapshots.
- Corrective Action
Delete the snapshots that have captured the destination file.
- Syslog Message
%s
- Parameters
destroy_info (STRING): Status of the file operation.
wafl.ondemand.done
- Severity
NOTICE
- Description
This message occurs when a file operation is completed.
- Corrective Action
(None).
- Syslog Message
%s
- Parameters
done_info (STRING): Status of the completed file operation.
wafl.ondemand.dst.fsize.exceeded
- Severity
NOTICE
- Description
This message occurs when the size of a file or LUN being moved or copied exceeds the maximum file or LUN size allowed by the system. The ondemand operation will fail for that particular file or LUN.
- Corrective Action
(None).
- Syslog Message
%s destination job %s-%d. %s %s%s%s%s, FSID 0x%x, The file operation with file ID %d has failed because the file size exceeded the maximum file size allowed on the current system, which is %lu bytes. The size of the file being copied or moved is %lu bytes.
- Parameters
job_type (STRING): Operation type.
job_uuid (STRING): Unique ID (UUID) of the file operation source job.
file_index (INT): Unique identifier for the file in the source job.
type (STRING): Type of object (volume or aggregate).
owner (STRING): Volume owner.
vol (STRING): Volume name.
volident (STRING): Unique identifier for the volume if the volume name itself is insufficient.
fsid (INT): File system identifier of the volume.
fileid (INT): File identifier.
maxsize (LONGINT): Maximum file size allowed on this system.
filesize (LONGINT): Size of the file being copied or moved.
wafl.ondemand.dstPresent
- Severity
INFORMATIONAL
- Description
This message occurs when a file shows up in the public name space of destination volume during file operation.
- Corrective Action
(None).
- Syslog Message
%s
- Parameters
file_info (STRING): Destination file's UUID and index.
wafl.ondemand.errPaused
- Severity
ALERT
- Description
This message occurs when a file or LUN operation is paused due to an error condition.
- Corrective Action
Based on the information in the event, resolve the problem that is causing the error condition, if possible. The operation is retried automatically on an hourly interval, or you can unpause the operation by using the appropriate command: file copy modify, file move modify, lun copy resume, or lun move resume. If the error condition persists, contact NetApp technical support.
- Syslog Message
%s
- Parameters
error_info (STRING): Error information for the paused operation.
wafl.ondemand.jobLookupFailed
- Severity
ERROR
- Description
This message occurs when an ondemand msg returns an error and, upon trying to check if snapshots are fenced during the cleanup process, cannot find the associated job.
- Corrective Action
Check if snapshots can be taken on the volume. If not, try to abort the previous job using either 'file copy destroy' or 'file move destroy'. If neither suggestions are successful, contact technical support for assistance.
- Syslog Message
OnDemand lookup job failed: %s
- Parameters
job_lookup_info (STRING): Information regarding the OnDemand msg.
wafl.ondemand.metafileErr
- Severity
ERROR
- Description
This message occurs when the special-purpose metafile that Data ONTAP® creates to store information on file operations cannot be read. The volume has been left offline as a consequence.
- Corrective Action
Issue the 'volume online' command to attempt to bring the affected volume back online. If this condition persists, contact NetApp technical support for futher assistance.
- Syslog Message
OnDemand metafile load error, volume '%s%s%s': %s
- Parameters
error_info (STRING): Error infomation.
wafl.ondemand.repaired.metafile
- Severity
ERROR
- Description
This message occurs when an inconsistency is discovered in the OnDemand metafile header or entry. The inconsistency is automatically repaired upon detection.
- Corrective Action
(None).
- Syslog Message
%s certification failed: %s, %s, %s, %s, %s, fbn (%llu), record_index (%llu)
- Parameters
fh (STRING): File handle of ondemand metafile which is repaired.
volident (STRING): Unique identifier of the volume in cases in which the volume name itself is insufficient.
condition (STRING): The initial metadata validation test that failed.
source (STRING): The location of the failing metadata validation test.
fbn (LONGINT): File block number (fbn) of the repaired block.
record_index (LONGINT): Index of the record entry in the repaired block.
wafl.ondemand.space.rsv.fail
- Severity
ERROR
- Description
This message occurs when Data ONTAP® fails to reserve space for a file operation due to lack of space on the volume.
- Corrective Action
Manually delete data to create free space on the volume, and then modify the job to unpause the data scanner by using the "volume file [copy|move] modify -job-uuid <job_uuid> -file-index <file_index> -scanner-paused false" command. If this condition persists, contact NetApp technical support for further assistance.
- Syslog Message
Insufficient space on '%s%s%s' to perform file operation %s-%d (failed to re-create %s flexible space pool).
- Parameters
job_uuid (STRING): Unique ID (UUID) of the file operation.
file_index (INT): Unique identifier for the file in the job.
wafl.ondemand.srcJobRecFail
- Severity
ERROR
- Description
This message occurs when the system fails to repair a corrupted record in the special-purpose metafile that holds information about file operations.
- Corrective Action
The source job recovery will be reattempted the next time the volume comes online. To explicitly reattempt the recovery, take the source volume offline and then bring it back online. If this error condition persists, contact NetApp technical support.
- Syslog Message
Volume %s%s%s: %s
- Parameters
result (STRING): Result of the failed recovery.
wafl.ondemand.srcJobRecovery
- Severity
NOTICE
- Description
This message occurs when the system repairs a corrupted record in the special-purpose metafile that holds information about file operations. If the file operation associated with the recovered source job is still in progress, the file operation can be resumed. Otherwise, the original source file can be recovered to lost+found by using the "file source recover" command.
- Corrective Action
(None).
- Syslog Message
Recovered file operation source job %s-%d in volume "%s%s%s".
- Parameters
wafl.ondemand.srcRecovered
- Severity
INFORMATIONAL
- Description
This message occurs when a file operation source recovery is completed.
- Corrective Action
(None).
- Syslog Message
Recovered %s source job %s-%d to {DSID:%d:%s}.
- Parameters
dsid (INT): Data set identifier (DSID) of the volume where the recovery was performed.
path (STRING): Path to the recovered object.
wafl.ondemand.started
- Severity
NOTICE
- Description
This message occurs when an OnDemand file or LUN operation is started. The "operation_info" parameter contains information on the type and identity of the started operation.
- Corrective Action
(None).
- Syslog Message
OnDemand operation started: %s
- Parameters
operation_info (STRING): Initial status of the OnDemand operation.
wafl.ondemand.volBusy
- Severity
ERROR
- Description
This message occurs when a volume operation fails because the volume is the source or destination of one or more file operations. Continuing with the volume operation could potentially disrupt file operations.
- Corrective Action
Make sure that file operations are making progress, and if they are paused unpause them. Retry the volume operation after the completion of the file operations.
- Syslog Message
Volume %s%s%s can not be offlined, until all pending file operations are completed.
- Parameters
