wafl.spacetax events
wafl.spacetax EMS events occur when the spacetax feature is disabled for all flexible volumes in the system because of the 'wafl-disable-spacetax?' boot option.
wafl.spacetax.disabled
- Severity
ERROR
- Description
This message occurs when the spacetax feature is disabled for all flexible volumes in the system because of the 'wafl-disable-spacetax?' boot option.
- Corrective Action
Reboot with the 'wafl-disable-spacetax?' boot option removed.
- Syslog Message
Spacetax disabled for all flexible volumes.
- Parameters
(None).
