ONTAP EMS reference
asyncdelcli.message events
asyncdelcli.message EMS events occur when ONTAP encounters issues associated with async-delete jobs starting or finishing on a specified path.
asyncDelCli.message.finish
Severity
NOTICE
This message occurs when an async-delete job has finished on the specified path.
Corrective Action
(None).
Syslog Message
Async-delete "%s" has finished on inode: %llu in volume (DSID: %llu, MSID: %llu). Number of files deleted: %llu, Number of directories deleted: %llu. Total number of bytes deleted: %llu. Path: %s.
Job_Id (STRING): Async-delete job ID.
Inode (LONGINT): Inode that is deleted.
volume_dsid (LONGINT): DSID of the volume containing the directory.
volume_msid (LONGINT): MSID of the volume containing the directory.
file_count (LONGINT): Total number of files deleted.
dir_count (LONGINT): Total number of directories deleted.
deleted_size (LONGINT): Total number of bytes deleted.
path (STRING): Target path to be deleted.
asyncDelCli.message.start
Severity
NOTICE
This message occurs when an async-delete job starts on the specified path.
Corrective Action
(None).
Syslog Message
Async-delete "%s" has started on inode: %llu in volume (DSID: %llu, MSID: %llu).
Inode (LONGINT): Inode to be deleted.
