callhome.dumptriage events
callhome.dumptriage EMS events occur when kernel dumptriage files are collected for a coredump event.
callhome.dumptriage
- Severity
NOTICE
- Description
This message occurs when kernel dumptriage files are collected for a coredump event. If your system is configured to do so, it generates and transmits an AutoSupport (or 'call home') message to NetApp technical support. Successful delivery of an AutoSupport message significantly improves problem determination and resolution.
- Corrective Action
(None).
- Syslog Message
Call home for %s
- Parameters
subject (STRING): AutoSupport subject or title for this event.
core_filename (STRING): Coredump filename used to find the correct set of dumptriage files.
