callhome.okm events
callhome.okm EMS events occur when the cluster has reached an inconsistent state with respect to the onboard key hierarchy.
callhome.okm.sync.needed
- Severity
ALERT
- Description
This message occurs when the cluster has reached an inconsistent state with respect to the onboard key hierarchy. This is an alert that the "security key-manager onboard sync" command should be run on the local cluster to prevent any future usage failures with onboard key management. If your system is configured to do so, it generates and transmits an AutoSupport (or 'call home') message to Netapp technical support and to the configured destinations. Successful delivery of an AutoSupport message significantly improves problem determination and resolution.
- Corrective Action
The Onboard Key Manager hierarchy is incomplete. Run the "security key-manager onboard sync" command to restore the Onboard Key Manager hierarchy.
- Syslog Message
Call home for CLUSTER OKM SYNC NEEDED
- Parameters
subject (STRING): AutoSupport subject or title for this event.
