cloud.azurecredsinvalid events
cloud.azurecredsinvalid EMS events occur when the system acquires Azure Managed Service Identity (MSI) credentials that are not valid.
cloud.azureCredsInvalid
- Severity
ERROR
- Description
This message occurs when the system acquires Azure Managed Service Identity (MSI) credentials that are not valid.
- Corrective Action
In the Azure Portal, find and check the health of the instance pertaining to this Cloud Volumes ONTAP® deployment. Also, verify that the MSI associated with the instance is enabled and grants proper privileges to the instance.
- Syslog Message
Azure MSI credentials that were acquired by ONTAP are not valid. Node UUID: %s.
- Parameters
nodeUuid (STRING): UUID of the node.
