ONTAP EMS reference
config.invalid events
config.invalid EMS events occur when a SAS (Serial Attached SCSI) port is attached to another SAS port.
config.invalid.PortToPort
Severity
ERROR
This message occurs when a SAS (Serial Attached SCSI) port is attached to another SAS port. This is not a valid connection.
Corrective Action
Check and correct the cabling; connecting two SAS ports together in this configuration is not permitted.
Syslog Message
SAS adapter "%s" is attached to another SAS adapter.
adapterName (STRING): Name of the associated SAS host bus adapter.
