ONTAP EMS reference
de.svm events
de.svm EMS events occur when an SVM (storage virtual machine) becomes inaccessible within the AI Data Engine (AIDE) cluster hindering scan, checks and updates on AIDE data.
de.svm.inaccessible
Severity
ERROR
This message occurs when an SVM (storage virtual machine) becomes inaccessible within the AI Data Engine (AIDE) cluster hindering scan, checks and updates on AIDE data.
Corrective Action
Verify NFS is enabled on the SVM with the command "vserver nfs show -vserver svm_name".If not, use "vserver nfs create -vserver svm_name -v3 enabled -v4.0 enabled".
Syslog Message
SVM %s with path %s is not accessible.
svmID (STRING): ID of the SVM.
svmPath (STRING): Path of the SVM.
