ONTAP EMS reference
fci.adapter events
fci.adapter EMS events occur when ONTAP encounters issues associated with the Fibre Channel adapter driver.
fci.adapter.bootarg.option
Severity
INFORMATIONAL
This message occurs when the the Fibre Channel adapter driver is setting an option based on the setting of a bootarg variable.
Corrective Action
(None).
Syslog Message
Bootarg option "%s" configured for Fibre Channel adapter %s.
option (STRING): Option being modified.
adapterName (STRING): Name of the associated Fibre Channel host bus adapter (HBA).
fci.adapter.dump.saved
Severity
NOTICE
This message occurs when an unexpected event or invalid condition is detected by the Fibre Channel(FC) initiator driver and the contents of the FC initiator memory is saved. Dump files are stored in a directory on the system's root volume at /etc/log, with the following directory name format: slifc_[adapterName][YYYYMMDD][HHMMSS]
Corrective Action
Send the dump file to technical support for analysis.
Syslog Message
A dump for adapter %s was stored in %s.
adapterName (STRING): Name of the associated FC host bus adapter.
filename (STRING): Name of the file containing the dump.
fci.adapter.error
Severity
NOTICE
This message occurs when the Fibre Channel adapter driver encounters an error with the adapter. The adapter will be reset to recover.
Corrective Action
(None).
Syslog Message
Fibre Channel adapter driver encountered error "%s" on adapter %s.
error (STRING): Type of error that occurred.
adapterName (STRING): Name of the associated Fibre Channel host bus adapter.
fci.adapter.fabric.login.failed
Severity
ERROR
This message occurs when the Fibre Channel adapter cannot log in with the fabric management server.
Corrective Action
The driver will attempt to recover from this error, but if this error keeps occurring, make sure that the switch is configured correctly and then try disconnecting and then reconnecting the adapter to the switch.
Syslog Message
Fibre Channel adapter %s cannot log in with the fabric management server for reason 0x%x.
status (INTHEX): Status returned from the adapter.
fci.adapter.fabric.ns.login.failed
Severity
ERROR
This message occurs when the Fibre Channel adapter cannot log in with the fabric name server.
Corrective Action
The driver will attempt to recover from this error but if this error keeps occurring make sure that the switch is configured correctly, and then try disconnecting and then reconnecting the adapter to the switch.
Syslog Message
Fibre Channel adapter %s was unable to log in with the fabric name server for reason 0x%x.
fci.adapter.fabric.request.failed
Severity
ERROR
This message occurs when the Fibre Channel adapter returns an unexpected status for a fabric query.
Corrective Action
The driver will attempt to recoverf rom this error but if this error keeps occurring make sure that the switch is configured correctly, and then try disconnecting and then reconnecting the adapter to the switch.
Syslog Message
Fibre Channel adapter %s returned unexpected status 0x%x for a fabric query.
fci.adapter.failed
Severity
ALERT
This message occurs when the Fibre Channel adapter driver cannot recover the adapter after resetting it multiple times. The adapter will be put offline.
Corrective Action
If the adapter is in use check the cabling, and if it is connected to disk shelves check the seating of the LRC/ESH cards and disks. If the problem keeps occurring try replacing the adapter. If the issue is still not resolved, contact NetApp technical support for assistance in diagnosing a Fibre Channel issue.
Syslog Message
Failed to recover Fibre Channel HBA %s after multiple resets. Taking the adapter offline.
reason (STRING): Diagnostic information.
fci.adapter.firmware.fault
Severity
NOTICE
This message occurs when a firmware fault is detected on the Fibre Channel adapter and it is being reset to recover.
Corrective Action
(None).
Syslog Message
Detected firmware fault 0x%x on Fibre Channel adapter %s.
faultCode (INTHEX): Firmware fault code.
fci.adapter.firmware.pause
Severity
NOTICE
Corrective Action
(None).
Syslog Message
Severity
INFORMATIONAL
This message occurs when a Fibre Channel adapter reports online link status, usually after the adapter is reset successfully.
Corrective Action
(None).
Syslog Message
Fibre Channel adapter %s link online.
fci.adapter.notification
Severity
NOTICE
This message occurs following a management request from the Fibre Channel(FC) driver to the host bus adapter.
Corrective Action
(None).
Syslog Message
Fibre Channel adapter driver notification: "%s" on adapter %s.
info (STRING): Description of the outcome.
fci.adapter.nvram.invalid
Severity
ALERT
This message occurs when ONTAP® software cannot read the NVRAM content of a Fibre Channel adapter. This might cause ONTAP to load an incorrect driver, which could cause the adapter not to work as intended. In addition, the World Wide Node Name (WWNN) and the World Wide Port Name (WWPN) will be incorrect and temporary ones will be assigned. This might cause fabric zoning not to work correctly and might cause problems with anything that depends on consistent WWNNs and WWPNs.
Corrective Action
Reboot the appliance. If the problem still exists, replace the adapter.
Syslog Message
Cannot read NVRAM content of Fibre Channel adapter %s.
fci.adapter.offline
Severity
INFORMATIONAL
This message occurs when the system takes a Fibre Channel adapter offline.
Corrective Action
(None).
Syslog Message
Fibre Channel adapter %s is now offline.
fci.adapter.offlining
Severity
INFORMATIONAL
This message occurs when the system takes a Fibre Channel adapter offline after all outstanding I/O requests have finished.
Corrective Action
(None).
Syslog Message
Taking Fibre Channel adapter %s offline.
fci.adapter.online
Severity
INFORMATIONAL
This message occurs when the system brings a Fibre Channel adapter online.
Corrective Action
(None).
Syslog Message
Fibre Channel adapter %s is now online.
fci.adapter.online.failed
Severity
ERROR
This message occurs when a Fibre Channel adapter fails to come online.
Corrective Action
If the adapter is in use check the cabling, and if it connected to disk shelves check the seating of the LRC/ESH cards.
Syslog Message
Fibre Channel adapter %s failed to come online.
fci.adapter.onlining
Severity
INFORMATIONAL
This message occurs when the Fibre Channel adapter begins the process of going online.
Corrective Action
(None).
Syslog Message
Onlining Fibre Channel adapter %s.
fci.adapter.speed
Severity
INFORMATIONAL
This message occurs when speed auto- negotiation for the Fibre Channel port is disabled because the administrator used either the 'ispfc-force-XG-only?' or the 'mptfc-force-XG-only?' boot argument in conjunction with the 'fc-force-XG-ports' boot argument to force a particular speed. For example, setting 'ispfc-force-2G-only?' to 'true' and setting 'fc-force-2G-ports' to '0a,0c' would force ports 0a and 0c to operate at a rate of 2 Gigabits per second.
Corrective Action
(None).
Syslog Message
The speed of Fibre Channel adapter port %s was forced to %u Gbps by link speed related boot arguments.
port (STRING): Name of the adapter port.
speed (INT): Speed the adapter port was assigned.
fci.adapter.topology
Severity
INFORMATIONAL
This message occurs when topology auto- negotiation for the Fibre Channel port is disabled because the administrator used either the 'fc-force-ptp-ports' or the 'fc-force-loop-ports' boot argument to force a particular topology.
Corrective Action
(None).
Syslog Message
Fibre Channel adapter port %s was forced to negotiate its topology as %s by topology-related boot arguments.
topo (STRING): Topology the adapter port was assigned.
