flexcache.origincleanup events
flexcache.origincleanup EMS events occur when ONTAP encounters issues associated with FlexCache origin volume cleanup operations.
flexcache.origincleanup.fail
- Severity
ERROR
- Description
This message occurs when the origin of a FlexCache® volume cleanup job fails to clean up the origin volume. All future FlexCache operations on the origin volume will fail.
- Corrective Action
Use the "volume flexcache origin cleanup-cache-relationship -force-retry true" command on the origin cluster to cleanup origin of a FlexCache volume. If the problem persists then contact technical support for assistance.
- Syslog Message
Origin volume cleanup job failed to clean up the origin volume of the FlexCache volume %s in Vserver %s in the origin cluster %s.
- Parameters
originVolName (STRING): Name of the origin volume of the FlexCache volume.
originVserver (STRING): Name of the Vserver hosting the origin of a FlexCache volume.
originClusterUuid (STRING): UUID of the origin cluster of a FlexCache volume.
flexcache.origincleanup.retry
- Severity
ERROR
- Description
This message occurs when the RAL cleanup at the origin volume of a FlexCache® volume fails due to timeout. All future FlexCache operations on the origin volume will fail.
- Corrective Action
- Syslog Message
RAL cleanup incomplete for the origin volume of the FlexCache volume %s in Vserver %s.
- Parameters
