ONTAP EMS reference
mgmt.mcc events
mgmt.mcc EMS events occur when MetroCluster(tm) switchback or switchover happens while applying a file security (fsecurity) policy on the MetroCluster partner.
mgmt.mcc.fsecurity.cfig.err
Severity
ERROR
This message occurs when MetroCluster(tm) switchback or switchover happens while applying a file security (fsecurity) policy on the MetroCluster partner. The policy was not applied to the partner.
Corrective Action
Reapply the policy by using the "vserver security file-directory apply" command. See the "vserver security file-directory" man pages for information. If the problem persists, contact NetApp technical support.
Syslog Message
Failed to apply file security policy "%s" on Vserver "%s".
policy (STRING): Fsecurity policy name.
vservername (STRING): Name of the Vserver.
