ONTAP EMS reference
mlm.bad events
mlm.bad EMS events occur when a device reports invalid data for "REPORT LUNS" command.
mlm.bad.topology.data
Severity
ERROR
This message occurs when a device reports invalid data for "REPORT LUNS" command. The invalid data may include one or more instances of duplicate LUN IDs and/or the "list length value" from the "REPORT LUNS" command may not match the amount of data received.
Corrective Action
Repair or replace the faulty hardware associated with the wwnn and wwpn
Syslog Message
The device with wwnn %s and wwpn %s is reporting inconsistent "REPORT LUNS" data.
wwnn (STRING): World Wide Node Name(wwnn) of the Device.
wwpn (STRING): World Wide Port Name(wwpn) of the Device.
