ONTAP EMS reference
nameserv.conf events
nameserv.conf EMS events occur when a UNIX user or group name exceeds 64 characters.
nameserv.conf.limit.reached
Severity
ERROR
This message occurs when a UNIX user or group name exceeds 64 characters. This check is performed on the last node upgrade from Data ONTAP® 8.2 to 8.3. The names that exceed this limit will not get resolved in Data ONTAP 8.3.
Corrective Action
Replace the name with a name that is no longer than 64 characters.
Syslog Message
%s exceeds 64 characters for Vserver %s and configuration %s.
name (STRING): Name of the user or group that exceeded 64 characters.
vserver_name (STRING): Name of the Vserver.
ns_config_name (STRING): Name of the name service configuration (unix-user or unix-group).
