netgroupbyname.cache events
netgroupbyname.cache EMS events occur when a host is checked for its membership in a netgroup that contains a large number of members.
netgroupbyname.cache.skip
- Severity
ALERT
- Description
This message occurs when a host is checked for its membership in a netgroup that contains a large number of members. In such cases, the netgroup.byname method produces an extended response and cannot be cached. Consequently, every lookup for hosts in that netgroup accesses the LDAP server.
- Corrective Action
Consider configuring the netgroup.byhost database on the LDAP server and enabling netgroup.byhost on the LDAP client configuration of the storage system by using the "ldap client modify" command.
- Syslog Message
netgroup.byname result for netgroup "%s" on SVM "%s" won't be cached since it's long.
- Parameters
netgroupName (STRING): Name of the netgroup for which the result is longer.
SVM (STRING): SVM name associated with this operation.
