ONTAP EMS reference
netif.phynotread events
netif.phynotread EMS events occur when the system cannot read identification information from the physical layer (PHY) of a network interface.
netif.phyNotRead
Severity
ERROR
This message occurs when the system cannot read identification information from the physical layer (PHY) of a network interface. This might be caused by a software bug or hung hardware, and the link might not come up.
Corrective Action
If the link does not come up, power-cycle (not just reboot) the system. If the link still does not come up, replace the motherboard or network interface card, depending on the location of the interface.
Syslog Message
Cannot read PHY for network interface %s, status mask=0x%llx.
ifName (STRING): Name of the network interface, for example, "e8a".
statusMask (LONGINTHEX): Technical information about the event for Data ONTAP® developers.
