ONTAP EMS reference
raid.spares events
raid.spares EMS events occur when ONTAP encounters issues associated with media scrub operations on spare disks.
raid.spares.media_scrub.media.err
Severity
NOTICE
This event is issued when a media_scrub i/o detects a medium error on a spare disk
Corrective Action
(None).
Syslog Message
Read error on %s%s, block #%llu during media_scrub
owner (STRING): String indicating the owner of the affected spare drive.
disk_info (STRING): The name of the disk object that contains the error.
blockNum (LONGINT): The physical block number containing the error.
shelf (STRING): Shelf identifier where the disk is located
bay (STRING): Disk bay within the shelf where disk is located
vendor (STRING): Name of the vendor of the disk
model (STRING): Model string of the disk drive
firmware_revision (STRING): Firmware revision number of the disk
serialno (STRING): Serial number of the disk
disk_type (INT): Type of disk drive
disk_rpm (STRING): Rotational speed of disk in RPM
carrier (STRING): Unique ID of the carrier in which the disk is installed.
site (STRING): For a MetroCluster(tm) configuration, indicates the site {Local|Remote} where the disk is located. For non-MetroCluster configurations, site is 'Local'.
raid.spares.media_scrub.media.recommend.reassign.err
Severity
NOTICE
This event is issued when a background media scrub i/o detects a recommend reassign error on a spare drive
Corrective Action
(None).
Syslog Message
Block recommended for reassignment on %s%s, block #%llu during media_scrub
disk_info (STRING): Formatted information of the disk object that contains the error.
raid.spares.media_scrub.rewrite.chunk
Severity
INFORMATIONAL
This message occurs when background media scrub rewrites a chunk of blocks for a spare ATA drive.
Corrective Action
(None).
Syslog Message
media_scrub rewriting chunk on %s%s, start block #%llu, count #%d.
owner (STRING): Owner of the affected spare disk.
disk_info (STRING): Information about the disk object, including disk name, path, shelf, bay, serial number, vendor, model, RPM, and carrier serial number.
blockNum (LONGINT): Physical block number at which the chunk starts.
count (INT): Number of blocks being rewritten.
shelf (STRING): Identifier of the shelf where the disk is located.
bay (STRING): Disk bay within the shelf where the disk is located.
vendor (STRING): Name of the vendor of the disk.
model (STRING): Model name of the disk.
firmware_revision (STRING): Firmware revision number of the disk.
serialno (STRING): Serial number of the disk.
disk_type (INT): Type of disk.
disk_rpm (STRING): Rotational speed of the disk, in RPM.
raid.spares.media_scrub.start
Severity
NOTICE
This event is issued when media_scrub is initiated on a spare drive.
Corrective Action
(None).
Syslog Message
(None).
blockNum (LONGINT): Disk block number at which media scrub started.
raid.spares.media_scrub.stopped
Severity
NOTICE
This event is issued when media_scrub stops on a spare drive.
Corrective Action
(None).
Syslog Message
(None).
raid.spares.media_scrub.suspend
Severity
NOTICE
This event is issued when media_scrub suspends on a spare drive.
Corrective Action
(None).
Syslog Message
(None).
blockNum (LONGINT): Disk block number at which media scrub suspended
percentage (INT): Percentage scan completed.
