repl.dst events
repl.dst EMS events occur when a SnapMirror® logical transfer is not possible due to an incompatible reference snapshot on the destination.
repl.dst.snaps.check.failed
- Severity
ERROR
- Description
This message occurs when a SnapMirror® logical transfer is not possible due to an incompatible reference snapshot on the destination.
- Corrective Action
Continue with physical transfers until a new snapshot is created on the source volume and the source volume is converted to dual inode space. Logical transfers can be started after this new snapshot is replicated to the destination volume.
- Syslog Message
SnapMirror operation failed because the reference snapshot on the destination volume is either a) from a release prior to Data ONTAP 8.2 b) captured in a nonclustered format c) not upgraded to dual inode space.
- Parameters
dstVolMsid (LONGINT): Destination volume Master Data Set ID (MSID).
dstVolDsid (LONGINT): Destination volume Data Set ID (DSID).
dstVolVserverId (INT): Destination volume Vserver ID.
dstInstanceRefImageUuid (STRING): Destination reference instance snapshot UUID.
dstVersionRefImageUuid (STRING): Destination reference version snapshot UUID.
